receiving calls while abraod
kend805
my don membership is paid till the end of the month.. i was able to receive calls yesterday but today i cant.. i can use my roaming texts.. shouldnt i be able to receive calls until my membership runs out?
@kend805 wrote:
i could make calls but my minutes are gone the last week
i am in norway
had credit but its now gone.. it was used up last night but thats the first time it used credit since i got here
Norway is not in the EU so I presume that the EU roaming texts/calls add-ons do not apply? But the price page is not that clear - it lists the EU roaming add-ons but does not explicitly list the countries that they apply to. However under standard EU roaming charges (that apply in the absence of an EU roaming add-on) it does list Norway.
http://www.48months.ie/boiler-plate/other-call-charges
If an EU roaming calls add-on does not apply to Norway (giving free incoming calls) then you need 8c/min to receive calls in Norway.
I suspect that you cannot receive calls because:
  • You have an EU roaming calls add-on but it does not apply to Norway
  • EU roaming calls add-on DOES apply to Norway but you don't have one
  • You have no credit
    or
  • There is some other technical problem in which case you need to contact support.
This is a process of elimination.
Can you make call's ?
What Country are you in?
Have you credit in your balance?
i am in norway
i am in norway
    or
As you suggested - you should still be able to receive call's since you have monthly membership.
See below:
EU Roaming -
EU roaming calls/text add-ons cover calls/texts to all international numbers and Irish numbers
You can buy more than one EU roaming add-on  in advance if you need more minutes and texts
You'll get a text when you have used up your roaming add-on allowances.
If you use up the 15 minutes you get with the EU roaming calls add-on you can still receive calls for free for the add-on month.
If you've used up the add-on allowances then your outgoing calls/texts will be charged from your credit balance.
Hi Again.
This need's some attention from 48 support... log a ticket using the link below:
Hopefully you will get sorted soon!
