problem buying stuff
Hi,
I am having a problem trying to top up or buy anything on the web page. When you click place order securely it just loads the page again. I need to get minutes now!! Anybody else having this problem?
Are you doing this on your phone on a carrier data connection with no data allowance left?
If so then try wifi or from a computer.
It may be this known issue with online payments/purchases:
http://community.48months.ie/t5/Need-Help/Can-t-pay-by-card/m-p/27011#M8553
Otherwise you may need to contact 48 support for assistance:
That worked! Thanks!
Great - thanks for posting back to report that it worked.
