Can't buy €12.99 plan - says problem with card
EndaM6936
I am trying to start a new plan and it keeps saying ops problem with card
Are you sure that your card is still valid?
If you're using the app then maybe try the website instead:
Or vice versa.
When did you last successfully make a purchase on 48 using this card?
Or anywhere else online or elsewhere?
