ppl can't hear me
robert121
When i make or receive calls i can talk to the person on the other end for 5seconds, den it gets noisy (like the wind blowing in the background) and they can't hear me.(i can hear them though) anybody know Wats going on?
2 ACCEPTED SOLUTIONS
You should log a support query so if you haven't done so already:
It may be a problem with your SIM that necessitates getting a replacement. You can do that here:
but that will disable your existing SIM immediately leaving you offline until the new one arrives.
Alternatively get a free new SIM:
http://48months.ie/free-sim
and when it arrives DON'T register/activate it but instead log a support request asking 48 if they can activate it on your existing account/number.
Ah - I'm just speculating as to what might be wrong - and I could be completely off track! 🙂 Best to test a bit more as you say and maybe log a support query anyway to get 48 on the case.
Are you sure that this isn't a handset rather than a network issue?
Can you try another handset with your 48 SIM to see if it's a handset issue?
robert121
Im after tryin my sim in a different phone but same thing happening. It came back working today but den went again. I think the teckie team might need some time to sort it out.
robert121
But Im only a member 2 weeks so the sim can hardly be broke by now, can it? I might try that over the next few days to give the team time. Cheers dalyer
