perfectly working phone. faulty sim and replacement sim won't activate
steve88n
I was told I had a faulty sim so order a new replacement. Turned out I had a new one and tried it to be told it wouldn't work so contact the agent. They won't reply and I'm stuck with a phone that works but no network. I've manually entered apn, searched for network, cleaned it, tried it in other phones.. I'm running out of options. Please help.
dc888
Crew (retired)
Crew (retired)
Hi Stephen
I can see you have been trrough a fair bit of troubleshooting already.  I can also see you have ordered a replacement SIM today.
Get back in touch when that arrives.
Damian
Any update?
