nexus 5 internet settings
hello,has anyone got internet settings for nexus 5 ?
I know it is made by lg....can not understand why it will not do set up automaticaly?
http://community.48months.ie/t5/Need-Help/Nexus-5/td-p/18447/jump-to/first-unread-message
Hi musky
Thesouptheif (Another 48'er) found success configuring their Nexus 5 by adding the details manually with some alterations.
Did you try it?
The full APN is listed click on the link on the top of my post... after input, power off - then on, & ensure data roaming is enabled
As you will see you will not have MMS...but, small price to pay for Internet!
Try the steps here:
The LG Nexus 5 (D820 and D821 models) is supported by the online configurator so that should work.
http://48months.tweakker.com/choose/LG/D820%20Nexus%205
http://48months.tweakker.com/choose/LG/D821%20Nexus%205
didnt work    any thing else i can try?
Hi musky
Did you try it?
Yep got it working...only prob now is I can only get an E for my internet ....02 signal is getting worse each week up here in Donegal....how do ya fix that?
Cheers paulio
Hi again
Glad you're sorted!
What's the 02 Signal like generally where your at?
I have a Nexus 7 Tab myself...Great Toy!
Anyhow - it's common on 02 to have H+ outdoors...then E indoors.
There's varying opinion on toggling between 2G & 3G with regard to Signal... personally I believe leaving it on Auto & let the handset pull in whatever is being pushed by the local area Mast...
But that's just me...
You can check comreg online to see how far the nearest 02 mast is from your home.
Ultimately, the closer you are to the Mast the better signal you'll recieve.
