need help
i was just woudering , i am buying a phone and its coming from Australia its a 2G network and i was just woudering will it work with you guys PLEASE HELP ASAP
If the phone is network unlocked, and Work's on the same frequency's as they do in Ireland- i can't see why not!!!
You should be able to check this online - & have a look on the site where you purchased the handset- it (should) provide a full description of the handset's capabilitie's... this should enlighten you further.
Remember to select Data Roaming when it arrive's & you've put your sim in, mind 😉
What's the phone make and model?
They do use some different frequencies in Oz so you will need to be careful just in case.
Why are you buying from there? Seems odd...
