how long is it taking people to transfer their numbers ?
my number is still being transferred but at this stage it is well over the 2 hours they said it would take ... was just wondering how long i can expect to be waiting 🙂
Hey
There are a few thing's to keep in mind during the porting process:
Have a little look below maybe some little thing troubleshooting-wise may apply to individual case's.
48 add they will get you over to the 48 network within the next 2 hours.
Please note: Number transfer hours are 8am to 6pm Mon to Fri, 10am to 4pm Sat and Sun.
If It's been over 2 hours: Log into your account -  If your transfer has failed you should see a message explaining that. It’s usually down to the wrong information being entered in the transfer form.
Double check the info and try again.
If it won’t let you try again contact the care crew http://help.48months.ie/requests/new .
hey thanks for the reply i dont think its failed it just keeps saying transfer in progres so suppose ill wait a while and see and if nothing happens then try contact someone
Glad to help.
Any further issue's...post your problem here & someone will get back to you.
