membership
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report this post
03-03-2014 09:56 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
03-03-2014 10:26 PM
Just to clarify - it displays the name of your membership when you log in?
What is the expiry date?
Do you get any signal at all?
Have you manually searched for and connected to 48 (or O2 if 48 is not listed)?
Do you have data roaming enabled? You need this even if not using data.
To use data you will also need to configure your internet settings:
If none of the above helps then you may need to contact 48 support for assistance:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
04-03-2014 09:17 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
04-03-2014 09:27 PM
You might need to contact 48 support for assistance here. See the link that I posted above - it links to the support request instructions.
