internet
Hi, my internet has not been working since around 4 yesterday. Is there any issues? I have taken my sim out a few times
Are calls/texts working OK?
Presumably you haven't used up your monthly membership or add-on data allowance? Your online account should clarify.
I'm not aware of any generate outage. A few other people reported problems over the weekend but didn't say where they were. I had no problems all weekend in/around Dublin.
If none of the above helps then you may need to get 48 to look into it.
