Will roaming including mobile data work in Turkey?
HelenS5645
Hi I'm travelling to turkey is internet will be working ok ?
HelenS5645
Hi is anyone can answer this question
Roaming services including mobile data are supported in Turkey.
But you need an active membership plan and cash credit on your account to pay for services.
See here:
However, lots of people continue to experience problems with roaming services in lots of countries/regions.
As such, the usual advice applies...
For roaming issues the usual advice applies:
