iMessage
My iMessage won't activate ever since I moved to the 48 network?
Any use?
http://community.48months.ie/t5/Need-Help/iMessage-amp-FaceTime-Activation/td-p/798
Remember that you may need to sync with iTunes and have a small amount of cash credit on your account to cover the cost of a UK text (25c) which will be sent to activate things.
7 REPLIES 7
Any use?
Seanc3790
I’m having the same problem here in Ireland
Did you put some cash credit on your account in order to pay for the SMS that the Apple activation mechanism sends to a UK activation server?
hexen269
Your post was blank @hexen269 - did you mean to post a question/issue?
hexen269
Your post was blank again @hexen269 - did you mean to post a question or issue?
