Sim not registered
colm02
My phone keeps telling me my sim not registered on network. Whats the problem
colm02
Iv been a customer for a few years using the same Sim and it just wasn't been recognised by the network. I took the Sim out and cleaned it and that seemed to work
11 REPLIES 11
More info needed...
Did it ever work?
Or are you new and just getting set up on 48?
If it worked before did anything change on your phone - e.g. settings changes, software update etc.?
Have you tried switching off, taking the SIM out, gently cleaning the contacts, reinserting it, switching on and then manually scanning for networks?
colm02
Yes its sorted. Thank you for your help.
What was the problem and solution?
It may help others in the same situation.
colm02
OK - thanks.
That's odd but maybe the phone got a knock and the SIM got nudged out of position so that it was no longer making good contact or something?
colm02
No phone didn't get a knock. Its not the first time this has happened but very rare
Maybe you should try a replacement SIM?
Did you contact 48 support about it to see if they can explain why it happens?
colm02
No but i will apply for a replacement sim thanks
