Roaming Not Working
bighat
Hi. I am travelling in Europe and my mobile data does not work. It works fine in my home country (Ireland). My membership is Guido and I have used none of my data allowance for this month. It is a nuisance to be reliant on wifi. Can this be fixed?
6 REPLIES 6
tatjana58
Hi.I am staying in ESTONIA now why i cannot call to Ireland I have a credit 12.35 euro
Do you have a Guido membership?
EU roaming only works on that membership and not any other.
https://www.48months.ie/membership-plans/going-abroad
If you do have a Guido membership...
What make and model of phone do you have?
Is it an iPhone by any chance?
If it is then this might be of relevance - if it is then you may have to try that tip many times before it works so be persistent. (Blame Apple for this sort of stupidity).
https://community.48months.ie/t5/Most-Popular-Questions/iPhone-abroad-issue/td-p/36862
If not can you do a manual search for networks and connect to a local one at all?
If necessary contact 48 support for more advice - see the link in my signature below.
Did that help at all @tatjana58 ?
LeonardB8354
My roaming is not working
