how to block a phone number
hey guys i have someone anoying me as feck i wana block his number but i dont no how i want ur help please message me thanks
Some phones offer a way to blacklist specific numbers on the handset itself. What handset and operating system do you have?
If that is not an option then you might need to log a support query to see if 48 can block a number at the carrier side for you.
And depending on the severity of the nuisance you might want to consider contacting the cops.
See also here:
http://community.48months.ie/t5/Need-Help/How-do-I-block-a-number-on-my-iPhone-4s/m-p/3900
See also here:
