Standard Membership
Hi,
Ive been a member with 48 for over a year, however my number got switched over but i switched back again with the same number, it wasnt intentional, but now the standard membership doesnt show up when i go to buy more.
Is there any way of getting it back?
Thanks,
Ronan
I guess that ronanp37 got a Vodafone SIM for a friend and mistakenly provided them with his number which got ported from 48 to Vodafone but left his 48 SIM back on the original 089 number until he re-ported his number back from Vodafone to 48 again?!?
10 REPLIES 10
I'm a bit confused by what exactly happened with your number along the way but if you were a member before 5th March 2013 then Standard €10 all calls/all texts membership should be an option for you to buy. Probably best to contact 48 support to see what they say about it.
My number got switched over when i bought a sim on vodafone for someone,
I didnt think much of it at the time but i got switched over, then i switched back!
Is there any way of getting the standard membership back?
You should contact 48 support about this so.
Sorry but i'm still confused!!!
You bought a Vodafone sim for someone else...but your own 48 number got changed to Vodafone network...
What kind of time-line are we talking here... you got accidently switched from 48 to Vodafone - for how long???
It's an interesting query.
As dalyer rightfully sugessted earlier, log a ticket with 48 support - & they will inform you of your membership option's.
Ive already emailed them about it,
I didnt know how to explain it better, thanks dayler.
Ronan
Could anyone help me plz, coz I bought a voucher of 10 euro twice but sti am being ssked to pay membership, how do I pay the membership, and can I not pay the membership from the 20 euro I have in already?? Thanx
Hi fabbi
So - you did correct buying your 'top-up' voucher's.
Now you need to either text to buy or go to your membership page & select a membership (ie The Don or The Guido ) to use the 48 service.
Pick one that will suit your usage... your account should address the fact you have a balance of the€20, so check this is the case.
Click below for a handy guide...
http://community.48months.ie/t5/Most-Popular-Questions-Knowledge/How-do-I-buy-my-membership/ta-p/268
Let me know when your up and running or need more help
