can recieve calls but not make any - just get beeping sound
Barryw2838
hi
since this evening, 18/12/20, i can recieve calls when roaming, but cant make them....just get beeping souund
anyone else? any solutions?
Do you have a current membership?
What type?
Where are you roaming?
yeah memebership by monthly DD, data and full coverage when roaming...i can send and recieve texts, data is working fine, i can recieve calls.....but just cant make calls.
roaming in northern ireland
what you think?
Maybe try connecting to another local network and see if that makes any difference?
You may have to contact 48 support though.
