Where is my credit
gloria99
I top up by €10 about 2 hours ago, but still have no credit or Internet access.
Perhaps you topped up your cash credit balance but never bought your membership or add-on?
Dial *100# - what cash credit balance is returned?
If it's €10+ then you probably still need to buy membership or add-ons.
If you already bought a new €10 membership are you sure that it is due to start immediately or if it has stacked until the current membership has ended?
A new membership does not start immediately if the current one has time left of its normal monthly period to run.
If you have a current membership that has time left to run and you have used up allowances then you need to buy add-ons.
Check your onlne account's Membership Planner to check the status of your current and next memberships as applicable.
gloria99
My membership will expire today hence I decided to buy a new membership. Does that mean my €10 is gone?
If your membership expires today 22th May then that means at midnight tonight.
If you bought a new membership then it will have stacked and will start after midnight when your current membership expires.
The €10 is gone because you pay for membership up front.
Does that clarify matters and does that tally with what you see on your online account's Membership Planner section?
