Voicemail - return a call
mkc
Hi. I got a voicemail yesterday. Person left their no. in the msg but it's crackles so missing a digit or two. Call doesn't show on my recent calls list. Is there any way I can find the no. of the person? There doesn't seem to be an option to return the call. Any ideas ? Cheers
Don't think you can get it from voicemail so.
If you're really stuck then you could ask 48 support if they can get it for you?
For what it's worth I also wish that the voicemail gave the option of retrieving the calling number and also the date/time of the call. Don't think that either is readily available?
