Voicemail not working after following *004* method
NiallW3421
Hi I've tried to activate my voicemail using *004*003538351234567#.
When I do this I get a message saying "Call Forwarding Registration was successful"
If I try to check the status using *#004# I get a message saying "Call Forwarding Connection problem or invalid MMI code" and my voicemail does not seem to kick in.
I requested a new sim to see if it would help but I am still having this issue.
Can anybody suggest a fix?
Thanks
Did you follow all of the instructions here?
https://community.48.ie/t5/The-Knowledgebase/How-do-I-use-my-Voicemail/ta-p/244
Edit: oh, just tried *#004# and call to get the status and I get the same error... Man Indifferent
You'll probably have to contact 48 support about this. See the link in my signature below.
