Top up minutes
Hi,
When i try to top up my minutes it flicks back to login and then I have to relogin in.
Tried it a few times and the same thing keeps happening
Yeah - it's a problem with the site at the moment as far as I can see and it's hitting several operations that would normally work. If you have enough cash credit already then you can try buying the add-on (?) by text:
How do I buy stuff by text?
If you need to contact support then since the online form mentioned here
seems to be problematic for some or all users right now you should try the email address:
[email protected]
[email protected]
