12m ago
4m ago - last edited 5 seconds ago
No, you can only use Flexi Data to swap call minutes for mobile data, not the other way around.
You don't need call minutes to receive calls.
You can even receive calls when you don't have an active membership plan.
If you don't have enough call minutes to cover your outgoing calls then you might want to consider switching to the €12.99 plan which comes with 5,000 Irish national call minutes.
Otherwise when you've used up your outgoing call minutes membership plan allowance you'll have to buy a calls minutes add-on in order to be continue to be able to make calls.
