Sim cards
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report this post
21-10-2013 09:07 PM
Hi, at the moment I have a normal sim card for a nokia phone but I am getting an iphone soon. Can i keep the current 10euro plan with all free texts and calls to any network? And how long would I be without a phone if i ordered a micro sim from 48? Thanks, Emer 🙂
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
21-10-2013 09:17 PM
Hi Emer
You have a few questions here, so I'll sort through them.
The good thing about 48 is that you can keep the same or change your membership on a monthly basis... this is left up to you to select a plan which suits your usage personally.
It can take 48 hours or 2 days for your new sim to arrive, however although this answers your questions... i can only answer your query thoroughly by getting an answer back from you!
Do you want a new 48 number... or a replacement number (same one you have, only a micro sim)?
Do post back!
Do post back!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
21-10-2013 09:49 PM - edited 21-10-2013 09:50 PM
If you want a micro SIM to replace your current mini SIM (with the same account, number etc.) but don't want to be offline while waiting for the micro SIM then see here:
As long as you were a member before 5th March then you can buy Standard €10 all calls/texts membership at any time even if you buy another membership at any stage.
