Signal keeps going
conaghan92
My signal keeps going for the past month now. Id have to restart my phone and sometimes that does not help. Other people i know with 48 have the same problem but not as much as me. The signal would come back for a few minutes and then it would go back to no service again. Can you please help with this
Try switching off, taking the SIM out, gently cleaning the contacts, reinserting it, switching on and manually scanning for networks and connecting to 48.
If that doesn't help the you might want to try a replacement SIM in case there's something faulty with your current one:
Need to swap your SIM?
Otherwise contact 48 support for advice:
