31-12-2015 10:07 PM
01-01-2016 12:49 AM
Just follow the instructions here:
01-01-2016 12:49 AM
01-01-2016 02:09 PM
01-01-2016 03:31 PM
01-01-2016 03:44 PM
01-01-2016 08:36 PM
01-01-2016 08:45 PM - edited 01-01-2016 08:47 PM
Standard membership changed in June 2015 so that it no longer comes with unlimited mobile calls - just 300 minutes per month.
http://www.48months.ie/boiler-plate/notice-of-changes
"From 10th June the Standard Membership (€10 plan available for existing customers only) will see the unlimited mobile voice allowance reduce to 300 minutes."
You should have been notified of this change by email at the time.
If you have used up your allowance then you need to buy add-ons to tide you over until the current membership expires and you can buy a new one.
Buying a new membership will not help immediately as it will only kick in when the current membership has run its full monthly course and expires normally.
Note that it's not worth buying Standard any more as Guido gives more (i.e. data allowance) for the same price.
Note also that €20 Don membership comes with 1000 mobile minutes per month:
02-01-2016 03:21 PM
