Sending/Receiving texts
bogueinator
I'm not sure if it is a problem with my phone or not but;
- When I send texts once, people not with 48 have said they recived my text two or three times.
- And when I receive texts from people on 48 I get the full original message and then seconds/minutes later, a duplicate of the 2nd half of the full message just received.
This doesn't happen with texts from other networks and I'm just wondering is it a coincidence and just my phone has suddenly stopped working, or does anyone else have a similar issue?
Thanks 🙂
I reckon you should contact 48 support about this as only they will be able to investigate it at their end to see if there's something up with incoming/outgoing texts.
What make and model of phone?
What app are you using for texts?
I see that you marked my reply as a solution.
What was the resolution to your problem?
