Samsung galaxy note 3
peter12345
How can I set up the Internet on my phone Samsung galaxy note 3 mi IMEI 351542/06/456803/9
6 REPLIES 6
See here
Test
peter12345
I can not still use the Internet
peter12345
I can not still use the Internet till date I don't know what to do again
Did you configure your internet/APN settings?
Do they match the ones here?
Post your settings if possible - screenshots are the best way.
Usually if you have a data allowance and have configured things but it still doesn't work then you most likely made a mistake configuring the settings.
This has happened more than once with others.
