Ringing
leonamahony24
Hi 48, every time I try ringin anyone in my phone book it just keeps ending so there is a problem with my network can u please sort it out ASAP because I have important calls to make thank u. Leona Mahony
Admin48
Crew (retired)
Crew (retired)
Hey there,
sorry about the trouble, we've been having some problems with our network but the techie guys are working on a fix. Check this thread to stay update about the progress: http://community.48months.ie/t5/Techie-Updates/Problem-with-outgoing-calls-27th-September-2013/td-p/...
8 REPLIES 8
Admin48
Crew (retired)
Crew (retired)
Hey there,
robertw
Your post is blank - did you mean to post a question?
elainemartin104
Hi 48 only with the past few days my phone keeps on running out of coverage in places that I all ways had very good coverage and when I be talking to people on my phone it wil just cut off. Even I took out my sim for a couple of mins and that didn't work either I really need my phone please help. thanks a mill
I reckon you need to contact 48 support for help with this assuming there's no problem with the phone itself (which there doesn't seem to be based on it working on before).
Maybe it's a faulty sim in which case a replacement might help.
Any update?
elainemartin104
I had this sim for a while and it was working fine don't know what is the problem tho.
Did you contact 48 support?
