SIM card
I ordered a new sim last Thursday at 1:30 or around then it said 2-3 working days it's still not here
Shouldn't take that long.
You should contact 48 support about the delay:
And/or you could just try ordering another one:
http://www.48months.ie/free-sim
Any update?
Still not here so I will just order a new one Monday thanks
Did you contact 48 support - just in case the same thing happens with a new order?
