Problems getting on 48 NETWORK IN LIMERICK !!
my phone wont let me make or receive calls and texts since Thursday evening I have tried many times to register manually on the 48 network and keep getting a message saying"this network is unavailable try later"Im wondering is anyone else having problems getting on the network in limerick ??
12 REPLIES 12
So you were able to call/text & receive same before Thursday?
Have you internet running as normal?
Have you toggle flight mode off then on, or powered your handset off then on & tried to use?
Try all the above & post us back.
Any possibility you could try your SIM in another phone just to see if it works there?
If not then it could be a SIM problem needing replacement?
You need a new SIM?
On the other hand it could be something else...
  I tried putting  sim into another phone  which is unlocked and it didnt work so i think i might need a replacement sim
 yeah i could revcieve and make calls and texts before thursday
i have tried putting airplan emode on and then off and also tuurnirng my phone on on off buti still cant get on the network
This is odd, im in limerick and it's working fine for me.
My guess is that its your handset.
Have you tried resetting network settings?
Hmmm
Odd indeed...
Obviously you have Data Roaming enabled...(?)
What is the status on your membership page? Any message's/notification's?
Have you contacted 48 support yet?
Have you logged a support request to get 48 to look into this for you?
 yeah, ive data roaming enabled
my current mebership status is "paid for guido" and there are no notifications or messages.
 yeah ive contacted  48 support but havent heard anything back yet !
Hey!
Did any of the suggestion's work?
Have you logged a ticket for support/Have support been in touch?
Post us back to let us know what the problem turned out to be - for the benefit of the 48 community!
