Problem with my application
I got an email saying I should check tay I applied for correct type of account, eg applied for prepaid unregistered instead of prepaid registered- which is what I did. But I don't know how to fix my appkication, it says 'transfer in progress'
You should probably log a support request to get 48 to look into this for you:
