Lost registration code
hi, i lost my registration code i dont know what to do because i cant register my sim. i order a replacement sim which i never receive. please i need help asap. thanks
Sounds like you will need a new SIM. If you need to activate a new SIM and don't have the registration code then I don't think that anybody, even 48 support, can do anything. But ask them just in case..
Did you lose your original SIM or are you just joining 48?
If you lost your original SIM then order a replacement here:
If you are just joining then order a new SIM here:
http://48months.ie/free-sim
If you don't get the SIM in a few days then contact support:
http://community.48months.ie/t5/Most-Popular-Questions/How-long-do-I-have-to-wait-for-my-SIM/m-p/26#...
