Number transfer in progress
fsxfan
Hello, I applied to keep my number with 48 on Friday evening, but it still shows transfer in progress. Can you help?
Thanks
Hi fsxfan
It shouldn't be taking this long so I suggest you send a message to one of the techie agents online here. They will see what's taking it so long and fix it for you.
Yours,
Camille
Community Helper
6 REPLIES 6
Hi fsxfan
Yours,
Camille
Community Helper
Sorry, forgot about this thread as I had to raise a support ticket. My old network are taking their sweet time to discontinue my number!
It could be helpful to contact them! 🙂
Same thing happening for me 😞
Log a support request to get 48 to look into the issue for you.
See the porting FAQ link posted above.
