Not receiving messages. Can receive and make calls and can also send texts.
It's the second time I haven't been able to receive texts, I have enough memory but still can't. Someone help please!!
How was the issue rectified the last time it happened?
You may need to contact support about this...
Have you tried resetting your network settings?
What do you mean by network settings?
APN? If so that has no relevance to SMS.
Hi leanneb30
I see you haven't posted on the forum regarding not receiving texts... im a bit confused on a few things.
You register date is December 17th - are we missing something? Have you a second 48 account?
Or did you have this problem with another carrier before?
Can you post back if you can add any info that can help narrow it down!
Hi leanneb30
I see you haven't posted on the forum regarding not receiving texts...so im a bit confused...
Or did you have this problem with another carrier prior to 48?
A little bit of history on the matter would be a help.
