No texts
Hi I couldn't get or send texts today??? And some calls didn't get through? Now at 7.45pm getting them??? Help
7 REPLIES 7
Never noticed any problem today myself.
What happened when you tried to send texts and they failed?
You might need to contact 48 support about this in case they know anything about it.
bigjoeod
Regular
Other networks when you have no texts left send you a text telling you you've no texts/credit.
While with 48 the text will fail to send.
As for not receiving texts/calls what was your signal like?
What was the other persons signal like?
________________________________
If I helped you out, you can help me out by giving me 'Kudous' (The big thumbs up button) and accepting my answer as the solution to your problem.
Slowly putting the laughter back into slaughter..
cheyennedevan
there, i just joined 48 and i cant send messages and i messages on my i phone 5. has anyone have the same problem?
@cheyennedevan
With 48 simply putting credit on your account isnt enough. You need to convert the credit on your account to a membership plan.
More is explained here
No I have plenty of credit and rose trying to get me had signal
Are you still having trouble sending texts?
Sometimes there can be a delay with receiving them. No harm to open a ticket with support
But for sending them there could be an issue with the message centre number on your phone.
Link here (kudos to dayler for his guide)
Credit is no use unless you are trying to send international texts which are charged from your credit balance at 25c a go.
What does your online account say about your membership status, expiry date and text allowance balance?
