No data connection.
donncha0
Hi All.
I've noticed the last few days I've had no data connection.
I'm guessing the issue has arose since I last bought my membership.
None have my settings have changed.
It just says it's disconnected because service is unavailable.
I'd there some issue I'm not aware of?
My apn is 48months.liffeytelecom.com
Thanks
Are you sure that your internet/APN settings are still correct?
Check here:
Also check if you still have a data allowance left.
Dial *100*98# to check.
donncha0
Check here:
donncha0
'Apn type' for some reason or other was blank.
Filled in those values & heh presto.
It needed a phone restart too I might add.
Ta very much.
Strange that it would have become blank - or worked before if it was blank - but at least you're all sorted again.
