No Data Connection on Samsung GT i5800
Hey, i have a problem connecting to the internet with my samsung. Apparently the APN Settings were deleted and i already tried to create a new one according to the steps in the community but it just doesnt save the settings and i cant turn on any Data connection. Data roaming is turned on...Anyone who knows what else i could try? Thanks a lot for any idea!
How did the APN settings get deleted? Did you do a factory reset of the phone or update the software or something? The APN settings shouldn't just disappear like that.
Have you tried the online configurator or the Tweakker APN app mentioned (post #4)  here?
Internet Settings
If you can't get it working then contact 48 support for assistance:
Internet Settings
