mms on htc hd7
kerryferris
Hi can anyone tell me why I am not receiving media messages just a message get content now then nothing happens. My internet is working fine ??
Can you send MMS? You will need credit to do this as it costs 30c to send an MMS.
Maybe double check your settings to ensure that they are correct - in particular that the APN type includes * or mms etc.
Internet Settings
This is the online configurator for your phone in case it helps:
http://48months.tweakker.com/choose/HTC/HD7
If all else fails contact 48 support:
Internet Settings
