My 3g internet won't work on my phone
I got a Huawei G510 for christmas and everything is working fine except I can't connect to the internet unless I'm using wifi. I have 1gb of data so that is not the problem.. Please help
Hi Again...
You say all other function's are working... (calls/texts) so i assume you have data roaming active already.
Usually the Tweakker works, but if it has not - time to log a support ticket using the link below.
Smiley Happy
13 REPLIES 13
Hi Alan,
It seems someone had this problem before; and it was solved in this thread here ::
http://community.48months.ie/t5/Need-Help/Internet-HUAWEI-G510/m-p/7426/highlight/true#M2407
Hope this helps!
It didn't work but thanks anyway! haven't a clue what to do now
Raise a ticket in the link below with a member of tech staff, and hopefully they can help you!
Hi Again...
Smiley Happy
Post Crossed.
Smiley Happy
After I put in all the relevant details for the APN's, what do I do then? 🙂
It should just work if you have a data allowance with your membership or add-on.
If not then try rebooting the phone.
If it still doesn't work then review the steps here:
No tweakker didn't work either? If I reboot my phone will I lose any files?
Hi Alan
Strange...
A Reboot is simply switching off, then on your handset - there is no detrimental effect from doing so.
If you find you still have no internet after reeboot - contact support using the link below.
Smiley Happy
