My phone's internet is not working. Why
ali9
  • Date you bought your membership or internet add-on: internet 17-09-2014
  • The type of phone you have: bq spanish brand
  • Full list of settings you saved into your phone:
  • APN: 48months.lifeytelecom.com
  • Type APN:nms
  • MMSC: http://mmc/servlets/mms
  • Proxy MMS: 10.1.11.19
  • Puerto MMS: 8080
  • MCC: 272
  • MNC: 11
  • Type authotefic: PAP
  • Protocolo APN: IPv4
  • Protocolo de itenerancia APN: IPv4
  • tYPE CONEXION: sin especificar
  • Do you have data roaming switched on
  • Do you have an internet signal: yes
I'm assuming that this phone runs Android?
If so then I would delete any APNs already configured and then download/run the Tweakker APN app to configure the settings. See here:
Internet nor working
See my post above.
Follow the instructions to configure your apn/Internet settings correctly for Internet access to work.
