16-09-2013 07:51 PM
Can I get the moving code text sent in less than a 160 character text. My phone is old and can only deal with 1 message and the code is getting cut off by the 160 limit any work around out there can I find the code somewhere?
17-09-2013 04:57 PM
16-09-2013 10:38 PM
You mean the text with the porting security code?
I thought that this was a lot shorter than 160 characters?
Or is not?
Or are you talking about some other code/text?
If necessary contact 48 support for help:
17-09-2013 10:41 AM
The actual code is turncated, short a few numbers at the end of the message. I have tried it on 3 different hand sets and the result is the same. All the handsets are old simple nokia type phones that can only deal with 1 message at a time. A pain!!!
17-09-2013 10:44 AM - edited 17-09-2013 10:46 AM
I see. I can't remember what the porting code SMS looks like and didn't realise that it seems to span more than a single message. Can you borrow a more modern phone (unlocked or locked to your old network) to allow you to receive the whole message/code? If not then you might need to contact support about this as I suggested above. Good luck.
17-09-2013 10:51 AM
On your advice I have contacted 48 support last night so I will let you know how that goes.
I will have to get a 02 handset somewhere (smartphone)
Thanks
17-09-2013 11:14 AM
OK - good luck. A phone locked to O2 OR an unlocked phone will do it.
I'm surprised that your phones can't seem to handle multipart/concatenated SMS messages - my recollection is that even my ancient Nokias were able to receive them - possibly one at a time and not reassembled. But maybe I'm mistaken...
17-09-2013 04:57 PM
Support ported me accross so all good now![]()
17-09-2013 05:03 PM
Glad to hear you got it sorted. 🙂
