Media messaging not working
debsbow
Can anyone help I can't send picture messages or videos by text my whatsapp will work but regular messaging won't unless it's text only. I have enough credit/data I've tried sending it by iMessage with wifi enabled but it still won't work!
7 REPLIES 7
Does regular internet access work while not on wifi?
If not then you need to configure your internet/APN settings.
Follow the instructions here:
In some cases iMessage also needs activation before it will work.
Search the forum for previous posts on "iMessage activation" and you may find some useful information there.
Unfortunately I can't offer more specific advice because I don't use an iPhone and unfortunately they seem to be hassle to get working on some networks due to the stupid way that Apple do things.
debsbow
Thanks 👍🏻
debsbow
No problem with Internet otherwise everything else works
OK - you may need to look at the iMessage activation issue so.
Can you send any messages with iMessage - e.g. non picture messages?
debsbow
Ya no problem sending just the text but if add a photo/video won't send
OK check the forum for info about activating iMessage or contact 48 support for more assistance.
Any progress?
