5G not working well & how to opt out of 5xxxx messages?
dinnyb
I’ve recently changed to 5G and signal-coverage no better. Should I just revert to old 3G plan????
I also get texts from a 50000 number and want to stop, but to reply STOP won’t send. Anyone with any solutions? Thanks
What exactly do you mean by "signal-coverage no better"?
Do you mean the mobile data speeds?
Or simply the signal strength/stability?
Where are you located?
Are you sure that your APN settings are configured correctly?
Text "APN" to 50048 and follow the instructions to make sure that they are:
If you're having ongoing problems with the signal/connection then you should contact 48 support.
What do you mean?
There is no 3G plan.
All plans support 4G LTE.
The €12.99 plan also supports 5G.
48 doesn't allow texts to be sent to premium SMS 5xxxx numbers other than 50048.
See here:
You'll have to contact the sender directly and tell them to stop sending the texts.
Failing that maybe blacklist the number on your phone so you don't see them?
Update: as of December 2024 48 DOES now support sending texts to Premium SMS 5XXXX numbers!
