Lost phone
I lost my phone on Friday night, is there anyway you can track the sim?
I don't think that 48 can do that but maybe log a support query asking 48 support if this is possible. You might also want to consider requesting a replacement SIM so that your lost one gets deactivated and doesn't get used.
