Iphone picture messaging
manofthehour
Iv got my iphone 4s unlocked from vodafone. I have the internet setting entered as stated from the forums. Yet I can't recieve any pictures from other people. What do i need to do to get the pictures?
Plus i do have to keep changing the apn address back to 48 because it changes to vodafones apn address every so often. Any help please.
Hi,
regarding the picture messages, are you sure you have the MMS settings entered properly as well as the internet settings? This could be the problem.
Regarding the APN address, i haven't had a problem with mine (also an unlocked phone)... Maybe try restarting the phone with the APN address correctly entered before restarting.
Hi,
Whats an APN and what should i enter into it...? Cant send or receive any pics, im using an iphone 5c
If you mean for MMS then see here:
If you mean for iMessage then no settings are requried but iMessage may require activation which may require some cash credit on your account to cover the cost of the UK SMS that gets sent as part of Apple's activation process. This is an Apple issue and not something that 48 have control over.
