MMS
littlelee
I am trying to send an mms. I have done all the settings and have a 1e credit. So why does it not send?
16 REPLIES 16
Are you sure that your settings are correct?
Check them against this:
Does internet access work OK with your internet/APN settings?
littlelee
Yep. Done all this again just to make sure and still no difference. 😕😕
So post your settings here for review.
Screenshots are the best if possible.
Does normal internet access work?
littlelee
Where do i find them? I was doing it via the link. Yep internet is perfect
What link?
You mean the Tweakker online configurator?
If you did it that way then everything should be correct.
You seem to be using an Android (Samsung?) phone in which case your internet/APN settings should be under
System settings > More > Mobile networks > Access Point Names
or something similar to that.
If internet access (via the carrier network and not wifi) is definitely working correctly but MMS is not and you have cash credit and an active membership then a key thing to check is the APN type configuration. It should be "default,mms,supl" or "*" for MMS to work. In some cases you may see separate APNs for internet and MMS access but only one is needed and these instructions show you how to manually configure a single APN for both:
littlelee
Yes that link. Ok inshall try that now. Thank u 😊
Any update?
littlelee
I cant figure out the apn part?!
You'll have to explain in more detail than that.
As I said before if you have problems then you should ideally post screenshots of your internet/MMS/APN settings.
