Internet won't work
I have internet but it just doesn't seem to be working, it was working fine a few days ago I have a easing Galaxy s6
Samsung
This is not solved
Samsung Galaxy phones have an unfortunate habit of losing their settings for some reason.
I have never been able to get a reasonable explanation of why this is.
If your internet is not working then I would suggest double checking that all settings are still correct.
Use this guide as others may not be reliable:
If it still doesn't work then contact 48 support:
