Internet settings galaxy ace
Hello everyone! I have tried to set the internet settings on my phone, and when I am at the very end of it, I press the option Save APN and it doesn't create it. It just goes back to the previous phase and all the data dissapear. Please can I get any help? I have a samsung galaxy ACE. Thanks
Try rebooting your phone and then using Tweakker APN to configure your APN:
If that doesn't work you may need to contact 48 support for advice:
