Internet not working on my phone
vee94
My internet is not working all day on my phone. I usually have 3G but I can only use the internet when I'm around wifi.
8 REPLIES 8
Do you still have a data allowance?
Are your internet/APN settings still correct?
See here:
Did anything change on your phone - e.g. software update, changes to settings, reset etc.?
No nothing has changed on my phone
So do you have a data allowance left?
Are your settings correct?
If not then (re)configure them.
ye i have data left
how do you reconfigure
You haven't said what your settings are right now so I can't say whether or not reconfiguration is needed.
But if you want to just reconfigure anyway then see this thread:
Internet Settings
Or else just manually configure these settings as they work for me on ever phone that I have ever configured:
What phone make and model are you using?
so it says i have 4567mb of data left.
i have an iphone 4s and im on the don membership
OK so configure your settings again as explained in the links that I posted above.
