Internet not working on HUAWEI ASCEND g6-u10
elduffio6
I am having trouble with my 48 internet... have applied the correct internet settings on my phone but I am still getting no data even tho I have 'the don' membership...how do i get it working?
*edited title to match conversation* - Sheena
Try the online Tweakker configurator first - if that works then that's great - you're done!
If your specific phone model is not listed then try choosing one that is "similar" as that may also work.
If, as happens to many people including me, it does not work (e.g. never sends any configuration settings to your phone) then you will need to configure the settings manually so read on...
Make sure that your membership is active and you actually do have a data allowance through your membership or a data add-on.
  • MMS Proxy: 10.1.11.19
  • MMS Port: 8080
  • MCC: 272
  • MNC: 11
  • APN Type: default,mms,supl
If that APN Type doesn't work then try:
  • APN Type: *
Make sure that data is enabled.
If you configure these settings and they still don't work then please DOUBLE CHECK that you did not make any mistakes - e.g. some people have mistakenly entered 48.months.liffeytelecom.com instead of 48months.liffeytelecom.com etc. The settings must be entered EXACTLY as specified above.
If you already have internet/APN settings but they are different to those above then reconfigure your settings so they match those above or delete any existing APNs and start again and add the 48 one anew.
If internet/data still does not work after configuring the settings correctly then try powering off and on again and maybe manually scanning for networks and connecting to 48.
How do I add/configure an APN on my phone?
You need to check the documentation and user interface for your phone for specific instructions.
However on most Android phones the process is similar although there may be slight differences how to navigate the menu options to get to the right place and slight differences in the options that can be configured.
See here for an example of a general guide for Android phones:
Similarly for iOS the specific menus/options may differ depending on the phone and version of iOS. But this is what Apple have to say about it:
And here is another third party guide (which may or may not be for a specific version of iOS):
If necessary search the web for specific instructions for your phone.
A note about personal hotspot setup on iPhones
Once you have your internet APN set up and data/internet access working you can also use this connection as part of a personal hotspot (this will probably use up your data allowance more quickly than "normal" internet access so keep an eye on your quota and that you don't breach the fair usage limits).
This is generally straightforward on Android but Apple sometimes make it more difficult on some iPhones/iOS versions for some reason...
Some people find that their iPhone/iOS iOS 8?) does not show the personal hotspot option in which case the following workaround may be required:
But note:
  1. At around 1 minute into that video he has Personal Hotspot > APN = gadget. Enter 48months.liffeytelecom.com instead.
  2. At around 2 minutes into that video he has Mobile Data > APN = internet and also Personal Hotspot > APN = internet. Enter 48months.liffeytelecom.com instead.
A note about 4G dongles/routers
If you're using a 4G dongle/router rather than a phone then you'll need to refer to the device's user manual for instructions on how to configure its APN/internet settings (and maybe SIM PIN unless you disable this in a phone first). Most or all such devices run a small web server that provides the management interface and which you connect to using your web browser.
96 REPLIES 96
Thank you for this, you solved my issue you beautiful helpful angel.
jade1996
Need help I Tried everything with inter and it still won't work help
If you follow this post carefully you should get it working:
did not work and all the settings are the same
Do calls/texts work?
Did you check all of the issues mentioned in that post (e.g. data roaming, you have a data allowance etc.)?
Are you 100% certain that all settings are correct?
Did you try the two different APN type settings mentioned as sometimes one works and the other doesn't?
Can you post screenshots of your settings?
If it still doesn't work then you'll have to contact 48 support and see if they can advise.
sorry, yes all my calls and texts work. yeah i have allowence, im sure my settings are correct because i went onto the model of my phone and they told me all the settings to wright in and i did it and there perfect.. what two different ''APN''..... my model is iphone 4, how do i post them screenshots of settings to you
How exactly did you configure your settings?
Manually or using the Tweakker online configurator?
If you can't post screenshots then list out all of your settings and post them here like this:
MMS Port: 8080
MCC: 272
MNC: 11
etc.
i got it working thanks so much
Great.
What was the problem?
It might help others in the same situation.
Do you have to have credit for this to work cause I don't think it is working for me ?
